Einleitung
If your Asus ZenBook Flip (model UX360C) screen isn’t producing clear visuals, distorted images, has a cracked screen, or has no visuals, use this guide to replace the screen.
The laptop transmits information to LCD screen through an auxiliary cord. A faulty or cracked screen will transmit distorted visuals or no visuals at all.
Was du brauchst
Use a spudger to pry out the two rubber grommets from the front of the screen.
Remove the two 4mm Phillips Head #1 screws behind the grommets.
Use a large plastic opening tool to work around the outside of the screen and gently separate the two halves.
Remove the two 2 mm Phillips #00 camera screws.
Remove the 2 mm Phillips #0 upper circuit board screw.
Remove the 2 mm Phillips #0 lower circuit board screw.
Use tweezers to unplug the two ribbon cables from the top half of the screen.
Detach the upper circuit board cable using the same method.
On the bottom half of the screen remove the screen connection.
Disconnect the lower circuit board cable.
Separate the wiring from the casing, and remove the screen.
