Zum Hauptinhalt wechseln
Asus ZenBook Flip UX360C Speaker Replacement
Was du brauchst
  1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: Schritt 1, Bild 1 von 3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: Schritt 1, Bild 2 von 3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: Schritt 1, Bild 3 von 3
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus ZenBook Flip UX360C Speaker Replacement, Speaker: Schritt 2, Bild 1 von 1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
    Frag FixBot
  3. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
    Frag FixBot
  4. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to remove the keyboard panel.
    Frag FixBot
  5. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
    Frag FixBot
  6. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 6, Bild 1 von 3 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 6, Bild 2 von 3 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 6, Bild 3 von 3
    • Use nylon-tipped tweezeres to detach the battery connection.
    Frag FixBot
  7. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove all ten Phillips #1 battery retaining screws.
    Frag FixBot
  8. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, carefully remove the connector connecting the speakers to the motherboard.
    Frag FixBot
  9. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 9, Bild 1 von 3 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 9, Bild 2 von 3 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 9, Bild 3 von 3
    • Use your fingers or another object to slightly raise the bottom edge of the battery. The battery does not need to be fully removed to replace the speakers.
    • Use a nylon spudger or an opening tool to carefully pry the speaker from the chassis.
    • The speaker is held down with a mild adhesive. Work your way around the border to fully remove the speaker.
    Frag FixBot
  10. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 10, Bild 1 von 2 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 10, Bild 2 von 2
    • Use tweezers to carefully unseat the cable connecting the left and right speakers.
    Frag FixBot
  11. Asus ZenBook Flip UX360C Speaker Replacement: Schritt 11, Bild 1 von 3 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 11, Bild 2 von 3 Asus ZenBook Flip UX360C Speaker Replacement: Schritt 11, Bild 3 von 3
    Frag FixBot
Abschluss
IUPUI, Team 1-4, Harley Spring 2022 Mitglied von IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 41
Insgesamt: 975
