Zum Hauptinhalt wechseln
Asus ZenFone 2 Laser ZE550KL Display Replacement
Was du brauchst
  1. Asus ZenFone 2 Laser ZE550KL Display Replacement, SIM and battery removal: Schritt 1, Bild 1 von 1
    • Remove the back cover.
    • Disconnect the battery.
    • Remove the SIM card and the micro SD card.
  2. Asus ZenFone 2 Laser ZE550KL Display Replacement, Remove the screws: Schritt 2, Bild 1 von 1
    • Unscrew the 15 screws
  3. Asus ZenFone 2 Laser ZE550KL Display Replacement, Internal back cover: Schritt 3, Bild 1 von 2 Asus ZenFone 2 Laser ZE550KL Display Replacement, Internal back cover: Schritt 3, Bild 2 von 2
    • Remove the plastic back with opening picks making sure not to break the clips that hold it in place
  4. Asus ZenFone 2 Laser ZE550KL Display Replacement, Flat cable display: Schritt 4, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Flat cable display: Schritt 4, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Flat cable display: Schritt 4, Bild 3 von 3
    • Disconnect the two flat cables by lifting the white bracket
    • Unplug the camera
  5. Asus ZenFone 2 Laser ZE550KL Display Replacement, Rear speaker: Schritt 5, Bild 1 von 2 Asus ZenFone 2 Laser ZE550KL Display Replacement, Rear speaker: Schritt 5, Bild 2 von 2
    • With the help from a spudger, remove the rear speaker
  6. Asus ZenFone 2 Laser ZE550KL Display Replacement, Motherboard: Schritt 6, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Motherboard: Schritt 6, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Starting from the bottom lift the motherboard
  7. Asus ZenFone 2 Laser ZE550KL Display Replacement, Frame Assembly: Schritt 7, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Frame Assembly: Schritt 7, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Frame Assembly: Schritt 7, Bild 3 von 3
    • Mother board.
  8. Asus ZenFone 2 Laser ZE550KL Display Replacement, Touchscreen driver: Schritt 8, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Touchscreen driver: Schritt 8, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Touchscreen driver: Schritt 8, Bild 3 von 3
    • Disconnect the touchscreen driver to remove the screen
  9. Asus ZenFone 2 Laser ZE550KL Display Replacement, Screen removal: Schritt 9, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Screen removal: Schritt 9, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Screen removal: Schritt 9, Bild 3 von 3
    • With the help of a hair dryer, heat gun or an iOpener remove the screen from the phone's frame
  10. Asus ZenFone 2 Laser ZE550KL Display Replacement, Preparation of the new screen: Schritt 10, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Preparation of the new screen: Schritt 10, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Preparation of the new screen: Schritt 10, Bild 3 von 3
    • Remove glue residues on the perimeter of the frame
    • Re-adhere the display
  11. Asus ZenFone 2 Laser ZE550KL Display Replacement, Screen adhesive: Schritt 11, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Screen adhesive: Schritt 11, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Screen adhesive: Schritt 11, Bild 3 von 3
    • apply the double-sided adhesive to the frame
  12. Asus ZenFone 2 Laser ZE550KL Display Replacement, New screen: Schritt 12, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, New screen: Schritt 12, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, New screen: Schritt 12, Bild 3 von 3
    • Replace or reposition the dust gasket of the front camera before installing the new screen
    • Insert the new screen into position by passing the flat into the specific grooves
  13. Asus ZenFone 2 Laser ZE550KL Display Replacement, Reassembly: Schritt 13, Bild 1 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Reassembly: Schritt 13, Bild 2 von 3 Asus ZenFone 2 Laser ZE550KL Display Replacement, Reassembly: Schritt 13, Bild 3 von 3
    • Refit the logic board
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
it en
100%
Hier starten ›
gwsLabs
457 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Just had my cracked LCD replaced. Everything was working fine before the replacement but after that, a third of a centimeter and all the subkeys (Back, Home, Recent keys) we rented working. The tech tried to checkout the fitting but it still didn't work. Had to install an assistive key app to be able to use the phone. He told me to go back on Thursday to replace the LCD with a different one cuz this last unit they had might be defective. Could it be a screen seating problem or an issue related to glue remnants or excess adhesive?
CJ Ogasawara - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 4,887
