Einleitung
The MicroSD card is one of the most common replacements for the ZenFone 5, and luckily, one of the easiest. The only tool required is a pin to fit in a small hole on the phone. If you do not have an advanced toolkit, some common household objects can also work, such as a thumbtack, needle, etc.
Was du brauchst
If you have a case, remove it so you can see the sides of the phone.
The slot for the MicroSD card, with the screen facing up, is on the left edge with a small hole.
Use your safety pin (or any tool with a small pin) to press into the hole until you feel a button being pressed.
Pull the pin out of the slot and the cartridge will come with.
Gently take out the MicroSD card.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
