Zum Hauptinhalt wechseln
Asus ZenFone 5 Motherboard Replacement
Was du brauchst
  1. Asus ZenFone 5 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Asus ZenFone 5 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Asus ZenFone 5 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
    • Pull out the SIM card tray.
  2. Asus ZenFone 5 Motherboard Replacement: Schritt 2, Bild 1 von 3 Asus ZenFone 5 Motherboard Replacement: Schritt 2, Bild 2 von 3 Asus ZenFone 5 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
    • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
    • Move all the way around the phone until the back cover is separated from the rest of the phone.
    • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
  3. Asus ZenFone 5 Motherboard Replacement: Schritt 3, Bild 1 von 3 Asus ZenFone 5 Motherboard Replacement: Schritt 3, Bild 2 von 3 Asus ZenFone 5 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
  4. Asus ZenFone 5 Motherboard Replacement: Schritt 4, Bild 1 von 2 Asus ZenFone 5 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
    • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
    • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
  5. Asus ZenFone 5 Motherboard Replacement: Schritt 5, Bild 1 von 2 Asus ZenFone 5 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Gently use a spudger to remove the wired connections on the motherboard.
    • Disconnect both ribbon cables by popping up the locking tab of the zif connectors and pulling the cable out.
    • Pry up the black coaxial cable and it will pop off its connector on the motherboard.
    • Remove the two screws holding down the motherboard with a Phillips #00 screwdriver.
  6. Asus ZenFone 5 Motherboard Replacement: Schritt 6, Bild 1 von 3 Asus ZenFone 5 Motherboard Replacement: Schritt 6, Bild 2 von 3 Asus ZenFone 5 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Insert the pointed end of a spudger into the red rubber divot underneath the motherboard.
    • Gently pry the motherboard from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,654
