Einleitung
The following guide is a step by step process for removing and replacing the battery on an Asus ZenWatch 2. Battery replacement may become necessary if there are issues with battery longevity and charging. Outside of a basic tool kit, no special requirements are needed to successfully replace the ZenWatch 2 Battery
Was du brauchst
Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
12 Kommentare
Where do you get the battery?
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
Only one place I know of to find them: http://www.asusparts.eu/Asus-0B200-01630...
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
