Einleitung
For the LCD screen, initially, follow the battery replacement guide, then disconnect the LCD connector from the motherboard. Separate the screen by unscrewing the hinges and pulling the screen from the device. From there you must open up the screen by removing a vent, bezel, and rubber o-ring. Finally, you disconnect three cables and unscrew the screen to complete the guide.
  1. Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward  the back of the computer. There are two length of screws. Eight screws are  3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge. There are two length of screws. Eight screws are  3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  2. Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard. Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard. Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
  3. Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
  4. Lift the battery directly up and remove it from the device. Lift the battery directly up and remove it from the device.
    • Lift the battery directly up and remove it from the device.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Remove the tape wrapped around the LCD connector by pulling it towards the screen hinges of the computer. Disconnect the LCD connector by sliding it out of its socket. Disconnect the LCD connector by sliding it out of its socket.
    • Remove the tape wrapped around the LCD connector by pulling it towards the screen hinges of the computer.
    • Disconnect the LCD connector by sliding it out of its socket.
  7. Using a Phillis #1 screwdriver, remove the four 3 mm screws at the screen hinges to allow the screen to pull off of the device. If the hinges are too hard to remove by hand, use the leverage of the keyboard to slide them out. If the hinges are too hard to remove by hand, use the leverage of the keyboard to slide them out.
    • Using a Phillis #1 screwdriver, remove the four 3 mm screws at the screen hinges to allow the screen to pull off of the device.
    • If the hinges are too hard to remove by hand, use the leverage of the keyboard to slide them out.
  8. Remove the plastic vent from screen by using an iFixit opening tool to pry the vent from the screen edge. Exercise caution when prying the vent off. Too much deflection can cause the vent to snap. Work both ends.
    • Remove the plastic vent from screen by using an iFixit opening tool to pry the vent from the screen edge.
    • Exercise caution when prying the vent off. Too much deflection can cause the vent to snap. Work both ends.
  9. Remove the nine 3 mm screws along the base of the screen using a Phillips #1 screwdriver. Remove four 5 mm screws along the two internal hinges using a Phillips #1 screwdriver. These four screws are hidden by cables and need to be removed in order to see the screws.
    • Remove the nine 3 mm screws along the base of the screen using a Phillips #1 screwdriver.
    • Remove four 5 mm screws along the two internal hinges using a Phillips #1 screwdriver.
    • These four screws are hidden by cables and need to be removed in order to see the screws.
  10. Remove the rubber o-ring (the thin rubber strip that lines the bezel edge)  by peeling it off. Heat the bezel using any heating tool such as a hair dryer, etc. Use a metal spudger to help rip off the bezel and the rubber-o-ring.
    • Remove the rubber o-ring (the thin rubber strip that lines the bezel edge) by peeling it off.
    • Heat the bezel using any heating tool such as a hair dryer, etc.
    • Use a metal spudger to help rip off the bezel and the rubber-o-ring.
  11. Disconnect the LCD connector from the screen housing by pulling the connector. Disconnect the LCD connector from the screen housing by pulling the connector.
    • Disconnect the LCD connector from the screen housing by pulling the connector.
  12. Unscrew the two 2 mmm screws that line the screen control board using a Phillips #1 screwdriver. Unscrew the two 2 mmm screws that line the screen control board using a Phillips #1 screwdriver.
    • Unscrew the two 2 mmm screws that line the screen control board using a Phillips #1 screwdriver.
  13. Remove the cable connecting the screen housing to the control board by pulling the cable. Remove the cable connecting the screen housing to the control board by pulling the cable. Remove the cable connecting the screen housing to the control board by pulling the cable.
    • Remove the cable connecting the screen housing to the control board by pulling the cable.
Abschluss
Zachary Eslick
621 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S22-G1, Maness Spring 2018 Mitglied von Cal Poly, Team S22-G1, Maness Spring 2018
CPSU-MANESS-S18S22G1
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 420
