Zum Hauptinhalt wechseln
Asus Zenbook UX303L Speaker Replacement
Was du brauchst
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: Schritt 7, Bild 1 von 1
    • Carefully peel away the defective speakers from the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ryan Snow
202 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G6, Harley Spring 2019 Mitglied von IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Is the Asus UX303L same as U303L?
Michael Wolf - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 28
Insgesamt: 1,794
