Zum Hauptinhalt wechseln
Asus Zenbook UX303L Trackpad Replacement
Was du brauchst
  1. Asus Zenbook UX303L Trackpad Replacement, Trackpad: Schritt 1, Bild 1 von 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Trackpad Replacement: Schritt 2, Bild 1 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 2, Bild 2 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Remove five Phillips #1 screws from the battery pack.
  4. Asus Zenbook UX303L Trackpad Replacement: Schritt 4, Bild 1 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 4, Bild 2 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Unhook the red, black, and white coiled switch.
    • Detach the positive and negative red, black, yellow, and white switch from the motherboard.
    • Unhook the black and white coiled wire from the top of the battery pack.
  5. Asus Zenbook UX303L Trackpad Replacement: Schritt 5, Bild 1 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 5, Bild 2 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Remove the three screws connecting the SSD to the motherboard.
    • Gently lift and pull out the SSD.
  6. Asus Zenbook UX303L Trackpad Replacement: Schritt 6, Bild 1 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 6, Bild 2 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 6, Bild 3 von 3
    • Remove the screw attaching the cooling fan to the motherboard.
    • Lift and remove the cooling fan.
  7. Asus Zenbook UX303L Trackpad Replacement: Schritt 7, Bild 1 von 2 Asus Zenbook UX303L Trackpad Replacement: Schritt 7, Bild 2 von 2
    • Remove the four Phillips #1 screws attached to the black covered copper bar next to the cooling fan.
    • Gently lift and remove the copper bar.
  8. Asus Zenbook UX303L Trackpad Replacement: Schritt 8, Bild 1 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 8, Bild 2 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 8, Bild 3 von 3
    • Remove the silver tape to reveal the fourth screw on the motherboard.
    • Detach the motherboard by removing the four Phillips #1 screws.
    • Detach the white wire connecting the motherboard by lifting the black flap and pulling it out.
  9. Asus Zenbook UX303L Trackpad Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • By using ESD-safe tweezers, remove the gray colored wire.
    • Remove the white wire using tweezers.
    • Remove the blue colored wire by lifting the black flap and pulling the blue flap out.
  10. Asus Zenbook UX303L Trackpad Replacement: Schritt 10, Bild 1 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 10, Bild 2 von 3 Asus Zenbook UX303L Trackpad Replacement: Schritt 10, Bild 3 von 3
    • Remove the white wire with the blue ends by lifting the black flap with tweezers and gently pulling out.
    • Gently remove the silver tape using tweezers.
    • Remove the Phillips #1 screws.
  11. Asus Zenbook UX303L Trackpad Replacement: Schritt 11, Bild 1 von 2 Asus Zenbook UX303L Trackpad Replacement: Schritt 11, Bild 2 von 2
    • Place the plastic opening tools under the trackpad.
    • Gently pull out and remove the trackpad.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Sam Houston State, Team 1-3, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 1-3, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G3
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
This laptop comes with a very bad trackpad, it has very low resolution. Do you think it can be updated?
eduugr - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 5,953
