Zum Hauptinhalt wechseln
Asus Zenbook UX31A Fan Replacement
Was du brauchst
  1. Asus Zenbook UX31A Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Zenbook UX31A Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Fan Replacement: Schritt 3, Bild 1 von 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Fan Replacement, Fan: Schritt 5, Bild 1 von 2 Asus Zenbook UX31A Fan Replacement, Fan: Schritt 5, Bild 2 von 2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Fan Replacement: Schritt 6, Bild 1 von 3 Asus Zenbook UX31A Fan Replacement: Schritt 6, Bild 2 von 3 Asus Zenbook UX31A Fan Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Fan Replacement: Schritt 7, Bild 1 von 2 Asus Zenbook UX31A Fan Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the fan connector by puling on it horizontally until it disconnects.
    • Remove the fan.
Abschluss
Brendan Walsh
227 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 23
Insgesamt: 447
