Zum Hauptinhalt wechseln
Asus Zenbook UX31A Motherboard Replacement
Was du brauchst
  1. Asus Zenbook UX31A Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Zenbook UX31A Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
    Frag FixBot
    Kommentar hinzufügen
  2. Asus Zenbook UX31A Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
    Frag FixBot
  3. Asus Zenbook UX31A Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
    Frag FixBot
  4. Asus Zenbook UX31A Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the laptop by lifting it up and out.
    Frag FixBot
  5. Asus Zenbook UX31A Motherboard Replacement, Wi-Fi Card: Schritt 5, Bild 1 von 2 Asus Zenbook UX31A Motherboard Replacement, Wi-Fi Card: Schritt 5, Bild 2 von 2
    Frag FixBot
  6. Asus Zenbook UX31A Motherboard Replacement: Schritt 6, Bild 1 von 2 Asus Zenbook UX31A Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
    Frag FixBot
  7. Asus Zenbook UX31A Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
    Frag FixBot
  8. Asus Zenbook UX31A Motherboard Replacement, Fan: Schritt 8, Bild 1 von 2 Asus Zenbook UX31A Motherboard Replacement, Fan: Schritt 8, Bild 2 von 2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
    Frag FixBot
  9. Asus Zenbook UX31A Motherboard Replacement: Schritt 9, Bild 1 von 3 Asus Zenbook UX31A Motherboard Replacement: Schritt 9, Bild 2 von 3 Asus Zenbook UX31A Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
    Frag FixBot
  10. Asus Zenbook UX31A Motherboard Replacement: Schritt 10, Bild 1 von 2 Asus Zenbook UX31A Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the fan connector by pulling on it horizontally until it disconnects.
    • Remove the fan.
    Frag FixBot
  11. Asus Zenbook UX31A Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 3 Asus Zenbook UX31A Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 3 Asus Zenbook UX31A Motherboard Replacement, Motherboard: Schritt 11, Bild 3 von 3
    • Disconnect the bundled connectors by pulling the cable away from the connector in the same direction that the individual wires are running.
    • Disconnect the ZIF connector by using the tip of the spudger tool or your fingernail to lift the locking tab. Then, gently pull the cable out.
    Frag FixBot
  12. Asus Zenbook UX31A Motherboard Replacement: Schritt 12, Bild 1 von 1
    • To disconnect the display connector, use the iFixit opening tool and pry the connector up and away from the board.
    Frag FixBot
  13. Asus Zenbook UX31A Motherboard Replacement: Schritt 13, Bild 1 von 3 Asus Zenbook UX31A Motherboard Replacement: Schritt 13, Bild 2 von 3 Asus Zenbook UX31A Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws that hold the motherboard in place.
    • Use a Phillips #000 screwdriver to remove the single 4 mm screw.
    Frag FixBot
  14. Asus Zenbook UX31A Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove the motherboard.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 51
Insgesamt: 1,852
