Zum Hauptinhalt wechseln
Asus Zenbook UX31A Wi-Fi Card Replacement
Was du brauchst
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 2 von 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Asus Zenbook UX31A Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Abschluss
Sherwin
209 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 275
