Zum Hauptinhalt wechseln
Asus Zenbook UX31E Battery Replacement
Was du brauchst
  1. Asus Zenbook UX31E Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Battery Replacement: Schritt 2, Bild 1 von 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Asus Zenbook UX31E Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Battery Replacement: Schritt 4, Bild 1 von 2 Asus Zenbook UX31E Battery Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Battery Replacement: Schritt 5, Bild 1 von 2 Asus Zenbook UX31E Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Hersi Dahir
203 Reputation
1 Anleitung geschrieben
UW Tacoma, Team 1-2, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
Thanks for the easy to understand guide. Cheers!
Rahul Kashelani - Antwort
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
fiddyfadhlina - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 7,819
