Was du brauchst
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Disconnect the fan connector from the motherboard.
Pull up the clips on the ribbon connectors.
Using a plastic opening tool, lift the fan off of the laptop.
You can now use your hands and carefully pull the fan off the laptop.
