Zum Hauptinhalt wechseln
Asus Zenbook UX31E Fan Replacement
Was du brauchst
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: Schritt 2, Bild 1 von 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: Schritt 3, Bild 1 von 2 Asus Zenbook UX31E Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: Schritt 5, Bild 1 von 2 Asus Zenbook UX31E Fan Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: Schritt 6, Bild 1 von 2 Asus Zenbook UX31E Fan Replacement: Schritt 6, Bild 2 von 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Abschluss
Sinh
101 Reputation
1 Anleitung geschrieben
UW Tacoma, Team 1-2, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,715
