Zum Hauptinhalt wechseln
Asus Zenbook UX31E SSD Replacement
Was du brauchst
  1. Asus Zenbook UX31E SSD Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E SSD Replacement: Schritt 2, Bild 1 von 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E SSD Replacement, SSD: Schritt 3, Bild 1 von 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  4. Asus Zenbook UX31E SSD Replacement: Schritt 4, Bild 1 von 2 Asus Zenbook UX31E SSD Replacement: Schritt 4, Bild 2 von 2
    • Using your hand, pull the SSD out from its slot.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team 1-2, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Vorrei fare una precisazione, l’SSD che monta questo laptop ha un attacco XM11, oramai non si usa più, pertanto è vero che possiamo sostituirlo ma dobbiamo aver cura di prendere un SSD M2 (2280) e un adattatore, io ho trovato su Amazon questo https://www.amazon.it/gp/product/B00XJRQ...
e ho preso come SSD un Crucial MX500 CT1000MX500SSD4 SSD Interno, 1 TB, 3D NAND, SATA, M.2 (2280)
Davide Bortot - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 48
Insgesamt: 12,075
