Einleitung
If your audio is distorted, replace the speaker component to get fresh, clear sound.
Was du brauchst
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Remove the screw connecting the speaker component to the motherboard using the screwdriver.
Using the plastic opening tool, pry open the speaker component from the computer.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
