Zum Hauptinhalt wechseln
Asus Zenbook UX32VD HD Web Camera Replacement
Was du brauchst
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: Schritt 1, Bild 1 von 1
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 2, Bild 1 von 3 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 2, Bild 2 von 3 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 2, Bild 3 von 3
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
    Frag FixBot
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 3, Bild 1 von 3 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 3, Bild 2 von 3 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 3, Bild 3 von 3
    • Remove display screen frame completely before adhesive cools and hardens.
    Frag FixBot
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 4, Bild 1 von 2 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 4, Bild 2 von 2
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    Frag FixBot
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 5, Bild 1 von 3 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 5, Bild 2 von 3 Asus Zenbook UX32VD  HD Web Camera Replacement: Schritt 5, Bild 3 von 3
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
    Frag FixBot
Abschluss
CSU Fullerton, Team 2-2, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare zur Anleitung
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Antwort Teilen
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 47
Insgesamt: 2,331
