Zum Hauptinhalt wechseln
Asus Zenbook UX32VD Battery Replacement
Was du brauchst
  1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $9.99
    Frag FixBot
    Kommentar hinzufügen
  2. Asus Zenbook UX32VD Battery Replacement: Schritt 2, Bild 1 von 3 Asus Zenbook UX32VD Battery Replacement: Schritt 2, Bild 2 von 3 Asus Zenbook UX32VD Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
    Frag FixBot
  3. Asus Zenbook UX32VD Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Asus Zenbook UX32VD Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
    Frag FixBot
  4. Asus Zenbook UX32VD Battery Replacement: Schritt 4, Bild 1 von 2 Asus Zenbook UX32VD Battery Replacement: Schritt 4, Bild 2 von 2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
    Frag FixBot
  5. Asus Zenbook UX32VD Battery Replacement: Schritt 5, Bild 1 von 3 Asus Zenbook UX32VD Battery Replacement: Schritt 5, Bild 2 von 3 Asus Zenbook UX32VD Battery Replacement: Schritt 5, Bild 3 von 3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    Frag FixBot
  6. Asus Zenbook UX32VD Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery completely.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
CSU Fullerton, Team 2-2, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Mitglieder
6 Anleitungen geschrieben
5 Kommentare zur Anleitung
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - Antwort Teilen
Will this method also apply to ASUS Zenbook UX430UQ ?
Kurt Scheel - Antwort Teilen
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - Antwort Teilen
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
Touko Korpela - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 75
Insgesamt: 18,837
