Einleitung
Use this guide to replace noisy or malfunctioning GPU fan in the Asus Zenbook UX32VD.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
Remove the bottom panel from the body of the laptop.
Set aside the bottom panel.
In diesem Schritt verwendetes Werkzeug:Spudger$2.99
Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
Remove the metallic ribbon cable from the connector .
In diesem Schritt verwendetes Werkzeug:Phillips #0 Screwdriver$5.49
Remove the 3 (4mm) fan screws with a Phillips #0 Screwdriver
Unplug the bundled cable connector.
Pull the cable away from the connector in the same direction as the individual wires are running.
