Zum Hauptinhalt wechseln
Asus Zenbook UX32VD Hard Drive Replacement
Was du brauchst
  1. Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $9.99
    Kaufen
  2. Asus Zenbook UX32VD Hard Drive Replacement: Schritt 2, Bild 1 von 3 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 2, Bild 2 von 3 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Hard Drive Replacement, Battery: Schritt 3, Bild 1 von 2 Asus Zenbook UX32VD Hard Drive Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Hard Drive Replacement: Schritt 4, Bild 1 von 2 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Hard Drive Replacement: Schritt 5, Bild 1 von 3 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 5, Bild 2 von 3 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery completely.
  7. Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 3 Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: Schritt 7, Bild 2 von 3 Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: Schritt 7, Bild 3 von 3
    Phillips #0 Screwdriver
    $5.49
    Kaufen
  8. Asus Zenbook UX32VD Hard Drive Replacement: Schritt 8, Bild 1 von 3 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 8, Bild 2 von 3 Asus Zenbook UX32VD Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Lift the hard drive slightly and gently pull the hard drive from the socket.
    • Do not lift the hard drive too high. Doing so could damage the hard drive or other internal components of the laptop.
    • Remove the hard drive completely.
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
CSU Fullerton, Team 2-2, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Mitglieder
6 Anleitungen geschrieben
4 Kommentare
Installed a new WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s 2.5"/7mm Solid State Drive into my UX32VD using this guide. It works like charm! Thanks for the guide
Le Zap - Antwort
Excellent! Precise and concise to the point!Thank you!
Android Phone - Antwort
Exzellent Guide, Thank you so much!
sina - Antwort
can someone confirm to me that samsung evo 860 will work or not for this asus please
Karim Othman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 10,863
