Einleitung
Replace or upgrade your hard drive in your laptop to gain more storage space!
Was du brauchst
In diesem Schritt verwendetes Werkzeug:T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
Remove the bottom panel from the body of the laptop.
Set aside the bottom panel.
Pry up each side of the flat connectors by hand or with a plastic opening tool.
Lift the connector straight up from its socket.
Unplug the two bundled cable connectors on each side of the battery.
Pull the cable away from the connector in the same direction as the individual wires are running.
In diesem Schritt verwendetes Werkzeug:Phillips #0 Screwdriver$5.49
Remove the four 3mm hard drive screws with a Phillips #0 Screwdriver.
Lift the hard drive slightly and gently pull the hard drive from the socket.
Remove the hard drive completely.
12 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
Excellent! Precise and concise to the point!Thank you!
can someone confirm to me that samsung evo 860 will work or not for this asus please
