Einleitung
If your Asus Zenfone 3 Max phone (Model-identification: ZC520TL) back cover is damaged or bent this guide will help you remove back cover and replace it with a new one. Before you begin, please note that the replacement of the back cover must be done with great care, as you can potentially damage other parts of the device.
Was du brauchst
Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
Move the opening tool up and down to pry the back off of the device.
