Zum Hauptinhalt wechseln
Asus Zenfone 4 Max Camera Replacement
Was du brauchst
  1. Asus Zenfone 4 Max Camera Replacement, Camera: Schritt 1, Bild 1 von 1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: Schritt 2, Bild 1 von 1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: Schritt 3, Bild 1 von 2 Asus Zenfone 4 Max Camera Replacement: Schritt 3, Bild 2 von 2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: Schritt 4, Bild 1 von 3 Asus Zenfone 4 Max Camera Replacement: Schritt 4, Bild 2 von 3 Asus Zenfone 4 Max Camera Replacement: Schritt 4, Bild 3 von 3
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Abschluss
Maegan West
839 Reputation
4 Anleitungen geschrieben
Sam Houston State, Team S11-G6, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S11-G6, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G6
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Antwort
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,939
