Einleitung
Tools you will need to remove and replace your SIM card include, a SIM card eject tool or a thin pointed object such as a pin or paper clip.
Was du brauchst
Locate the SIM tray on the left edge of the phone.
There is a small hole on the outside of the SIM tray that will be used for opening the tray.
Insert a SIM card eject tool into the hole.
Press until the SIM tray pops out slightly from the phone.
Once the SIM tray has been opened, gently pull the tray completely out of the phone.
Lift the old SIM card out of the tray with your fingers or flip the tray upside down to make the card fall out.
To reassemble your device, place the SIM tray back into the tray slot
