Zum Hauptinhalt wechseln
Asus eee PC 1015px HDD and cooling fan repalcement
  1. Asus eee PC 1015px HDD and cooling fan repalcement, Cooling fan: Schritt 1, Bild 1 von 1
    • Remove the battery.
  2. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 2, Bild 1 von 1
    • unscrew the 4 screws, purple arrow
  3. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 3, Bild 1 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 3, Bild 2 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 3, Bild 3 von 3
    • use a screwdriver to press in the 2 slots to unlock the keyboard hooks
  4. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 4, Bild 1 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 4, Bild 2 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 4, Bild 3 von 3
    • pry up the 2 side points to release the joints
    • Using a flat opening tool, unclip the keyboard along the perimeter
  5. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 5, Bild 1 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 5, Bild 2 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 5, Bild 3 von 3
    • unhook the keyboard
    • Disconnect the ribbon cable by opening the 2 black side latches
  6. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 6, Bild 1 von 2 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 6, Bild 2 von 2
    • Disconnect the 2 ribbon cables
  7. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 7, Bild 1 von 1
    • remove the screws, including the one under the yellow sticker
  8. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 8, Bild 1 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 8, Bild 2 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 8, Bild 3 von 3
    • Pry in the 2 points. Using a flat tool release the trackpad block along the perimeter
  9. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 9, Bild 1 von 2 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 9, Bild 2 von 2
    • unhook and remove the mouse block
  10. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 10, Bild 1 von 2 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 10, Bild 2 von 2
    • Remove heatsink and fan screws
    • Unhook fan ribbon cable
  11. Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 11, Bild 1 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 11, Bild 2 von 3 Asus eee PC 1015px HDD and cooling fan repalcement: Schritt 11, Bild 3 von 3
    • carefully clean the old Arctic cooling paste on the processor and heatsink
    • before reassembling put some new Arctic paste
    • To replace or remove HDD, unhook the 2 ribbon cables (purple arrow). Remove 2 screws (yellow arrow)
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
it en
100%
Hier starten ›
Smilzo
12.320 Reputation
39 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 98
Insgesamt: 2,923
