Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Repairing the motherboard of the Atari 5200.
  1. Flip your Atari Entertainment System over to its top so you can see the bottom.  You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Flip the Atari Entertainment System back over so that you can now see the top.
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. You will now have access to the motherboard.
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Zach Petryszyn
21 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 13-1, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Mitglieder
11 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 23
Insgesamt: 1,947
