Zum Hauptinhalt wechseln
Atari 5200 Joystick Repair
Was du brauchst
  1. Atari 5200 Joystick Repair, Opening the Controller: Schritt 1, Bild 1 von 3 Atari 5200 Joystick Repair, Opening the Controller: Schritt 1, Bild 2 von 3 Atari 5200 Joystick Repair, Opening the Controller: Schritt 1, Bild 3 von 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    Frag FixBot
    Kommentar hinzufügen
  2. Atari 5200 Joystick Repair, Locating the Knobs and Pots: Schritt 2, Bild 1 von 1
    • Find the knobs (closest to the joystick and circled in red).
    • Locate the pots (closest to the circuitry and circled in orange). Keep track of these.
    • Align the joystick's metal bar into its cup.
    • Don't move any of the button circuitry, especially those of the START/PAUSE/RESET buttons.
    Frag FixBot
  3. Atari 5200 Joystick Repair, Reassembly Part 1: Schritt 3, Bild 1 von 1
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
    Frag FixBot
  4. Atari 5200 Joystick Repair, Reassembly Part 2: Schritt 4, Bild 1 von 2 Atari 5200 Joystick Repair, Reassembly Part 2: Schritt 4, Bild 2 von 2
    • Realign the top and bottom of the controller.
    • Pull the circuit strip through the new space.
    Frag FixBot
  5. Atari 5200 Joystick Repair, Reassembly Part 3: Schritt 5, Bild 1 von 3 Atari 5200 Joystick Repair, Reassembly Part 3: Schritt 5, Bild 2 von 3 Atari 5200 Joystick Repair, Reassembly Part 3: Schritt 5, Bild 3 von 3
    • Return the start buttons to the top of the controller
    • Snap the frame back into place
    • Screw in the three screws on the back.
    Frag FixBot
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 13-1, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Mitglieder
17 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 70
Insgesamt: 4,336
