Zum Hauptinhalt wechseln
Atari 5200 Motherboard Cleaning
Was du brauchst
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: Schritt 1, Bild 1 von 1
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Atari 5200 Motherboard Cleaning: Schritt 2, Bild 1 von 1
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
    Frag FixBot
  3. Atari 5200 Motherboard Cleaning, Access: Granted: Schritt 3, Bild 1 von 1
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 13-1, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Mitglieder
17 Anleitungen geschrieben
1 Kommentar zur Anleitung
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 3,338
