Zum Hauptinhalt wechseln
Einleitung
The number pad, while not used in many games, can become unresponsive over time due to dislodged/dirty sensors. Reseating and cleaning them can improve number pad responsiveness.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws. Carefully slide and pull the two parts of the controller shell apart, exposing the innards. Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
    • Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
  2. Take out the rubber button module of the number pad. With access to the number pad sensors, use compressed air to blow out dust. Wipe the sensors clean with a cloth dabbed with alcohol.
    • Take out the rubber button module of the number pad.
    • With access to the number pad sensors, use compressed air to blow out dust.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  4. Use a spudger to remove the top frame. Take off the plate.
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  5. Pull the circuit strip through the new space. Realign the top and bottom of the controller.
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  6. Return the buttons to the top of the controller. Snap the frame back into place. Screw the screws.
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Alan Abelson
230 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 13-1, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Mitglieder
11 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 291
