Einleitung
If the button on an Atari Flashback 2 console is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the console in order to access the buttons to do so.
Was du brauchst
Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
2 Kommentare
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
