Zum Hauptinhalt wechseln
Atari Flashback 2 Reset and Select Button Replacement
Was du brauchst
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: Schritt 1, Bild 1 von 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: Schritt 1, Bild 2 von 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: Schritt 1, Bild 3 von 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
    Frag FixBot
    Kommentar hinzufügen
  2. Atari Flashback 2 Reset and Select Button Replacement: Schritt 2, Bild 1 von 3 Atari Flashback 2 Reset and Select Button Replacement: Schritt 2, Bild 2 von 3 Atari Flashback 2 Reset and Select Button Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    Frag FixBot
Abschluss
Washington State, Team S1-G2, Hope Fall 2018 Mitglied von Washington State, Team S1-G2, Hope Fall 2018
WSU-HOPE-F18S1G2
4 Mitglieder
11 Anleitungen geschrieben
2 Kommentare zur Anleitung
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Antwort Teilen
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 58
Insgesamt: 1,402
