Zum Hauptinhalt wechseln
Atmega328P Microcontroller Replacement for Arduino Board
Was du brauchst
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: Schritt 1, Bild 1 von 1
    • Place the Arduino UNO R3 board on a flat clean surface.
    Frag FixBot
  2. Atmega328P Microcontroller Replacement for Arduino Board: Schritt 2, Bild 1 von 2 Atmega328P Microcontroller Replacement for Arduino Board: Schritt 2, Bild 2 von 2
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
    Frag FixBot
  3. Atmega328P Microcontroller Replacement for Arduino Board: Schritt 3, Bild 1 von 2 Atmega328P Microcontroller Replacement for Arduino Board: Schritt 3, Bild 2 von 2
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
    Frag FixBot
  4. Atmega328P Microcontroller Replacement for Arduino Board: Schritt 4, Bild 1 von 3 Atmega328P Microcontroller Replacement for Arduino Board: Schritt 4, Bild 2 von 3 Atmega328P Microcontroller Replacement for Arduino Board: Schritt 4, Bild 3 von 3
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
    Frag FixBot
  5. Atmega328P Microcontroller Replacement for Arduino Board: Schritt 5, Bild 1 von 1
    • Remove replacement microcontroller out of packaging.
    Frag FixBot
  6. Atmega328P Microcontroller Replacement for Arduino Board: Schritt 6, Bild 1 von 1
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
    Frag FixBot
  7. Atmega328P Microcontroller Replacement for Arduino Board: Schritt 7, Bild 1 von 2 Atmega328P Microcontroller Replacement for Arduino Board: Schritt 7, Bild 2 von 2
    • Gently press the microcontroller into the dip socket
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team 5-5, Morris Winter 2023 Mitglied von UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 75
Insgesamt: 1,347
