Zum Hauptinhalt wechseln
Attach Backpack Straps on a Patagonia Lightweight Travel Tote
  1. Attach Backpack Straps on a Patagonia Lightweight Travel Tote, Understanding the buckle system: Schritt 1, Bild 1 von 3 Attach Backpack Straps on a Patagonia Lightweight Travel Tote, Understanding the buckle system: Schritt 1, Bild 2 von 3 Attach Backpack Straps on a Patagonia Lightweight Travel Tote, Understanding the buckle system: Schritt 1, Bild 3 von 3
    • Each backpack strap has a bottom buckle that separates into two pieces. This allows the straps to be detached and stashed away when not in use.
    • This tutorial will guide you through connecting and disconnecting these buckles properly.
    • Pull the backpack straps out of the top stash pocket on the back of the tote.
    • Find the bottom stash pocket along the bottom edge of the back of the tote.
    • Pull out the straps. You’ll find two on each side:
    • One set has standard buckles. This is the waist strap. You can connect these or put them aside for now.
    • The other set has clips that look like duck bills (Speedy Clips). This set is used for attaching the backpack straps.
  2. Attach Backpack Straps on a Patagonia Lightweight Travel Tote, Check the webbing placement: Schritt 4, Bild 1 von 3 Attach Backpack Straps on a Patagonia Lightweight Travel Tote, Check the webbing placement: Schritt 4, Bild 2 von 3 Attach Backpack Straps on a Patagonia Lightweight Travel Tote, Check the webbing placement: Schritt 4, Bild 3 von 3
    • The webbing (strap) that feeds through the the duck bill clip can come out or get misaligned. If it isn't threaded correctly, the buckle will not attach properly.
    • Ensure that the webbing is threaded through the duck bill clip as shown in the reference images.
    • Hold the duck bill clip behind the open square piece at the base of the backpack strap
    • Slide the duck bill clip through the top half of the square piece and pull the entire duck bill clip through the square piece.
    • Ensure all webbing from the duck bill clip stays behind the square piece.
    • Push the duck bill clip down onto the square piece, then press firmly until you hear or feel a click.
    • Test the connection by pulling gently on both sides. The webbing shouldn't slip.
    • The next step shows a side view for a different look at this procedure.
    • From the side, you’ll see the duck bill sliding into a channel at the top of the square piece.
    • Push the duck bill clip down firmly to lock it into place.
  3. Attach Backpack Straps on a Patagonia Lightweight Travel Tote, You did it!: Schritt 7, Bild 1 von 2 Attach Backpack Straps on a Patagonia Lightweight Travel Tote, You did it!: Schritt 7, Bild 2 von 2
    • With the backpack straps attached, your tote is now ready to be worn as a backpack!
    • Push the bottom of the duck bill clip up and away from the square piece.
    • Slide the duck bill clip out of the square piece.
    • Disconnect both Speedy Clip buckles.
    • Push the straps back into the bottom stash pocket.
    • Open the top stash pocket, slide the backpack straps down inside the pocket, and close the hook and loop fastener.
Ziellinie
Clara Redwood
2.544 Reputation
18 Anleitungen geschrieben
Patagonia Mitglied von Patagonia
Community
17 Mitglieder
168 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 37
Insgesamt: 127
