Zum Hauptinhalt wechseln
Audio-Technica AT-LP60BK-BT Belt Drive Replacement
Was du brauchst
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: Schritt 1, Bild 1 von 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: Schritt 1, Bild 2 von 2
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 2, Bild 1 von 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 2, Bild 2 von 2
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 3, Bild 1 von 1
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 4, Bild 1 von 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 5, Bild 1 von 1
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 6, Bild 1 von 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 6, Bild 2 von 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 6, Bild 3 von 3
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 7, Bild 1 von 1
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 8, Bild 1 von 1
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 9, Bild 1 von 1
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 10, Bild 1 von 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 10, Bild 2 von 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: Schritt 10, Bild 3 von 3
    • Test the function by spinning the platter and put the rubber mat into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zonghao Li
208 Reputation
1 Anleitung geschrieben
York University, Team S1-G15, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G15, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G15
1 Mitglied
Ein Kommentar
Thank you so much!
Joe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 28
Letzte 7 Tage: 149
Letzte 30 Tage: 679
Insgesamt: 8,299
