Einleitung
If the camera on your Audiovox is not working correctly or showing a black screen when trying to use the camera then you might need a camera replacement.
There is no need to purchase a new phone. Just replace the camera!
When starting this project, make sure you have a screwdriver, ifixit opening tool and the camera for the replacement ready. Be careful when unscrewing the screws, make sure you keep them in a safe place so you won't loss them. Also when opening the phone make sure you take it apart gently, that will help you separate the motherboard form the phone.
Step 6 requires you to take the motherboard and simply add the new camera carefully and verify that orient the camera correctly when reinserting.
Remember to carefully place everything back to it original place.
Was du brauchst
Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
Remove the small rubber insert from the top of the phone to access the top screw.
Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
Wedge the phone plate toward you, using the leverage from an opening tool.
Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
To release the motherboard, push the large "OK" button located on the other side of the phone.
