Einleitung
Here is how you replace the keypad if a button is missing.
If a button doesn't work, refer to Logic Board Repair Guide.
Was du brauchst
Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
Remove the small rubber insert from the top of the phone to access the top screw.
Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
Wedge the phone plate toward you, using the leverage from an opening tool.
Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
To release the motherboard, push the large "OK" button located on the other side of the phone.
Eine weitere Person hat diese Anleitung absolviert.
