Zum Hauptinhalt wechseln
Audiovox CDM-8910 LCD Screen Replacement
Was du brauchst
  1. Audiovox CDM-8910 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Audiovox CDM-8910 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Audiovox CDM-8910 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. Audiovox CDM-8910 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  5. Audiovox CDM-8910 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  6. Audiovox CDM-8910 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to lift away the LCD screen.
  7. Audiovox CDM-8910 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • LCD screen successfully removed!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kevin Jafarey
11 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-24, Regan Fall 2010 Mitglied von Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 2,896
