Einleitung
So the speaker in your Audiovox CR8030iE5 has not been producing any audio or has not been sounding good at all and you think you have to go buy a new one. Well, hold on! We have a simple fix for that.
Fortunately, if your audio does not work/sounds bad chances are you have a speaker going out and it needs to be replaced. We all know how important it is to hear quality audio.
Remember! Each speaker has a powerful magnet, so be sure to be very cautious of other metal surroundings.
Was du brauchst
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
Slide a plastic opening tool along the rim of the faulty speaker where it meets the plastic casing.
Using your thumb, applying constant pressure, pull back the plastic tab towards the speaker and away from the metal bracket.
Simultaneously insert a Phillips #00 screwdriver into the square hole on the underside of clock and push through to lift the metal bracket off of the plastic tab.
Pull up on the metal brackets, found on either side, until the speaker is completely removed. Removing the speaker is rather challenging. Don't get discouraged if it takes multiple attempts!
3 weitere Personen haben diese Anleitung absolviert.
