Was du brauchst
Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover.
NOTE: some force will need to be used to remove the cover. Avoid excessive force.
Pry under the aluminum touch screen to remove the remaining components from the front housing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
