Zum Hauptinhalt wechseln
  1. Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover. NOTE: some force will need to be used to remove the cover. Avoid excessive force. NOTE: some force will need to be used to remove the cover. Avoid excessive force.
    • Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover.
    • NOTE: some force will need to be used to remove the cover. Avoid excessive force.
  2. Remove the speakers.
    • Remove the speakers.
  3. Remove any adhesives (such as tape).
    • Remove any adhesives (such as tape).
  4. Pry under the aluminum touch screen to remove the remaining components from the front housing. Pry under the aluminum touch screen to remove the remaining components from the front housing.
    • Pry under the aluminum touch screen to remove the remaining components from the front housing.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Logan
367 Reputation
3 Anleitungen geschrieben
Penn State, Team 2-42, Kaschak Winter 2015 Mitglied von Penn State, Team 2-42, Kaschak Winter 2015
PSU-KASCHAK-W15S2G42
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 267
