Zum Hauptinhalt wechseln
August Smart Lock Speaker Replacement
Was du brauchst
  1. August Smart Lock Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 August Smart Lock Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 August Smart Lock Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Speaker Replacement: Schritt 2, Bild 1 von 3 August Smart Lock Speaker Replacement: Schritt 2, Bild 2 von 3 August Smart Lock Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
  3. August Smart Lock Speaker Replacement: Schritt 3, Bild 1 von 3 August Smart Lock Speaker Replacement: Schritt 3, Bild 2 von 3 August Smart Lock Speaker Replacement: Schritt 3, Bild 3 von 3
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
  4. August Smart Lock Speaker Replacement: Schritt 4, Bild 1 von 2 August Smart Lock Speaker Replacement: Schritt 4, Bild 2 von 2
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
William Fink
766 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S11-G6, Passmore Fall 2017 Mitglied von USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,446
