Einleitung
This is a basic guide to disassembling your Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 to access the core components of the appliance. If you are noticing issues with the burr grinder, water pump, heating element, control board, or any other component on the interior of the device, this guide will instruct you on how to access those parts. This will also allow you to open up the machine for cleaning and descaling of the brewing components.
Was du brauchst
Using a T10 screwdriver, remove the eight screws located on the rear panel of the device (4 towards the bottom, and 4 towards the top).
Unscrew one PH2 screw.
Use a spudger or a thin curved tool such as a dental pick to remove the bean hopper of the burr grinder.
Remove the grind selector by pulling the dial directly away from the machine which will remove it from the housing.
Unscrew the one 4mm Hex in a clockwise fashion and remove the black plastic cover over the burrset.
Remove the black plastic cover over the burr set.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
