Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Replacing the battery in the Tommy 20 is a relatively simple replacement, just make sure you have 3 replacement AA batteries ready to go beforehand along with a Phillips #1 Screwdriver! A good first step in any repair goal concerning the Tommy 20!
Ersatzteile
  1. Remove the single 1mm screw connecting the battery cover to the gun using a Phillips #1 screwdriver. Lift the cover away from the gun and remove.
    • Remove the single 1mm screw connecting the battery cover to the gun using a Phillips #1 screwdriver.
    • Lift the cover away from the gun and remove.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove all three batteries from compartment by pulling up on the positive end of each battery. Remove all three batteries from compartment by pulling up on the positive end of each battery.
    • Remove all three batteries from compartment by pulling up on the positive end of each battery.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Reed Garmsen
456 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-22, Maness Fall 2014 Mitglied von Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 343
