Zum Hauptinhalt wechseln
Autosampler Battery Enclosure Assembly (For Old & New Versions)
Was du brauchst
  1. Autosampler Battery Enclosure Assembly (For Old & New Versions), Drill the holes into the enclosure.: Schritt 1, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Drill the holes into the enclosure.: Schritt 1, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Drill the holes into the enclosure.: Schritt 1, Bild 3 von 3
    • 1. Drill a hole in the top right corner 16.5 mm from the top and 30.3 mm from the side using a 13/16 inch drill bit.
    • 2. Drill two holes in the side 30 mm from the short sides and 27 mm from the long side using a 1/2 inch drill bit.
    • 3. Screw in two waterproof cable gland connectors to the side holes.
    • Put in a button in the rocker switch in the other hole.
  2. Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery wires.: Schritt 2, Bild 1 von 2 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery wires.: Schritt 2, Bild 2 von 2
    • 4. Cut the purple wire and the inline fuse holder wire 10 inches long.
    • 5. Attach a 10A, 12VDC fuse.
  3. Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the wires for the batteries.: Schritt 3, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the wires for the batteries.: Schritt 3, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the wires for the batteries.: Schritt 3, Bild 3 von 3
    • 6. Strip both wires about 1/2 inch
    • 7. using the 16 gauge slot of the wire stripper
    • 8. Get 3 pink and 3 blue fully insulated heat-shrink quick-disconnect terminals.
  4. Autosampler Battery Enclosure Assembly (For Old & New Versions), Attach heat-shrinking terminals.: Schritt 4, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Attach heat-shrinking terminals.: Schritt 4, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Attach heat-shrinking terminals.: Schritt 4, Bild 3 von 3
    • 9. Crimp the fully insulated heat-shrink quick-disconnect terminal onto the end of the wire.
    • 10. Use the heat shrink gun to heat shrink the ends of the crimps.
    • 11. Repeat for both ends of both wires.
  5. Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 5, Bild 1 von 2 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 5, Bild 2 von 2
    • 12. Cut two feet of red and black 16G wire (grey insulated wire) and then strip 2 inches off of the grey insulation.
    • 13. Strip 1/2 inch of both the black and red wires.
  6. Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 6, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 6, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 6, Bild 3 von 3
    • 14. Place two metal contacts on both the red and black wires.
    • You should see copper wire through the little pin hole. If not, strip more insulation.
    • 15. Crimp the contacts into place.
    • 16. Thread the contacts into the Amphenol connector.
  7. Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 7, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 7, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Prepare the battery connector wire.: Schritt 7, Bild 3 von 3
    • 17. Attach the green wedge to the connector.
    • 18. Cut 1.5 inches of 2:1 0.25" diameter heat shrink tubing.
    • 19. Use the heat shrink gun to shrink the heat shrink tubing.
  8. Autosampler Battery Enclosure Assembly (For Old & New Versions), final battery connector.: Schritt 8, Bild 1 von 1
    • 20. This is what the final battery connector looks like.
  9. Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 9, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 9, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 9, Bild 3 von 3
    • 21. Cut 30 inches of red and black 16G wire (grey insulated wire). Strip 2 inches of the grey rubber coating from both ends.
    • 22. Strip 0.5 inches from both the red and black wires from both ends.
    • 23. Obtain a 2-pin amphenol connector.
  10. Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 10, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 10, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 10, Bild 3 von 3
    • 24. Disconnect the 2-pin amphenol connector into its individual parts.
    • 25. Loosen the screws on the amphenol connector. Thread the stripped wire through the end of the amphenol connector and through the middle piece of the amphenol connector.
    • The black GND wire should be in the “A” port and the red PWR wire should be in the “B” port.
    • 26. Solder the wires to the other end of the amphenol connector.
  11. Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 11, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 11, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 11, Bild 3 von 3
    • 27. Obtain a Flux Remover Pen, 99 % Isopropyl Alcohol, and a Q-Tip.
    • 28. Use the pen to remove the flux from the soldered pins.
    • 29. Dip the q-tip in the alcohol. Use the q-tip to remove the flux remover.
  12. Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 12, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 12, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Creating a 2-pin amphenol connector.: Schritt 12, Bild 3 von 3
    • 30. Screw the amphenol pieces back together. Then tighten the external screws.
    • 31. This is what a final 2-pin amphenol connector looks like.
    • 32. Thread the 2-pin amphenol autosampler wire through the top hole and the battery connector wire through the bottom hole of the enclosure box. Leave about a foot of each on the outside of the box. Tighten the glands.
    • Once 2 pin and battery wires constructed and threaded into box, strip opposite ends and add heat-shrinking quick disconnect terminals.
  13. Autosampler Battery Enclosure Assembly (For Old & New Versions), Connecting wires to the rocker switch.: Schritt 14, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Connecting wires to the rocker switch.: Schritt 14, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Connecting wires to the rocker switch.: Schritt 14, Bild 3 von 3
    • 33. This is what the wires look like threaded through the glands in the box.
    • 34. Connect the battery wire to the first two prongs of the rocker switch.
    • 35. Connect the 2-pin amphenol autosampler wire to the last two prongs of the rocker switch.
  14. Autosampler Battery Enclosure Assembly (For Old & New Versions), Connecting the battery in the enclosure.: Schritt 15, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Connecting the battery in the enclosure.: Schritt 15, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Connecting the battery in the enclosure.: Schritt 15, Bild 3 von 3
    • 36. Connect the purple wire and fuse wire to the middle two prongs of the rocker switch.
    • 37. Connect the other side of the purple wire and fuse wire to a 12 volt battery.
    • 38. A light goes on if the fuse is blown!
  15. Autosampler Battery Enclosure Assembly (For Old & New Versions), Completing the enclosure.: Schritt 16, Bild 1 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Completing the enclosure.: Schritt 16, Bild 2 von 3 Autosampler Battery Enclosure Assembly (For Old & New Versions), Completing the enclosure.: Schritt 16, Bild 3 von 3
    • 39. Place the 12V battery and all the wires into the enclosure.
    • 40. Screw the lid onto the enclosure.
    • 41. This is what the completed battery enclosure looks like.
  16. Autosampler Battery Enclosure Assembly (For Old & New Versions), Label the switch: Schritt 17, Bild 1 von 1
    • Label the switch with the label maker.
    • <-- Manual Mode
    • --> Node Trigger Mode
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brooke Mason
2.928 Reputation
17 Anleitungen geschrieben
Open-Storm Mitglied von Open-Storm
Community
14 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 180
