Einleitung
This guide will demonstrate how to replace the IR LED lightboard for your AvertX HD810 dome camera. This guide has one prerequisite guide labeled, 'Clear Dome Camera'. The two tools required for this guide are the T10 Torx security bit screwdriver and the PH1 (Phillips Head) screwdriver. It's important to that the camera turned off, and optimally, unplugged for this procedure.
Was du brauchst
Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
Loosen both 10mm screws on either side of the clear dome cover housing using a T10 Torx security screwdriver.
Use the PH1 screwdriver to remove or loosen both 10mm screws on either side of the inner protective lens cover. This will loosen both the cover and the IR LED lightboard.
Pull the IR LED light board gently away from the camera to expose the connecting cable.
Firmly but gently detach the IR lED light board from its cable connector by pulling directly away from the connection port.
Eine weitere Person hat diese Anleitung absolviert.
