Zum Hauptinhalt wechseln
Axe Empire 2.0 OLED Board Replacement
Was du brauchst
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: Schritt 1, Bild 1 von 2 Axe Empire 2.0 OLED Board Replacement, OLED Board: Schritt 1, Bild 2 von 2
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: Schritt 2, Bild 1 von 3 Axe Empire 2.0 OLED Board Replacement: Schritt 2, Bild 2 von 3 Axe Empire 2.0 OLED Board Replacement: Schritt 2, Bild 3 von 3
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: Schritt 3, Bild 1 von 3 Axe Empire 2.0 OLED Board Replacement: Schritt 3, Bild 2 von 3 Axe Empire 2.0 OLED Board Replacement: Schritt 3, Bild 3 von 3
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: Schritt 4, Bild 1 von 2 Axe Empire 2.0 OLED Board Replacement: Schritt 4, Bild 2 von 2
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: Schritt 5, Bild 1 von 2 Axe Empire 2.0 OLED Board Replacement: Schritt 5, Bild 2 von 2
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: Schritt 6, Bild 1 von 3 Axe Empire 2.0 OLED Board Replacement: Schritt 6, Bild 2 von 3 Axe Empire 2.0 OLED Board Replacement: Schritt 6, Bild 3 von 3
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: Schritt 7, Bild 1 von 2 Axe Empire 2.0 OLED Board Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the battery from the OLED board.
Abschluss
Christopher Ramos
345 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 11-2, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-2, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G2
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 198
