Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
    • Use metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
  2. Use Phillips head PH1 to remove the four 5mm Phillips Head  screws from the red panel (under mesh).
    • Use Phillips head PH1 to remove the four 5mm Phillips Head screws from the red panel (under mesh).
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
  5. Separate the red interface plate from the black face plate by pulling them apart.
    • Separate the red interface plate from the black face plate by pulling them apart.
Abschluss
Michael Bradley
477 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 8-6, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-6, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G6
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 26
