Einleitung
Removal of the plastic cover on the back of the Axess TA2513-10WT tablet will be necessary for any replacements within the tablet. These instructions will teach you how to remove the back cover either for back cover replacement or as a prerequisite for other part replacements.
Was du brauchst
Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
Slide the plastic opening tool gently along the sides.
Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
Eine weitere Person hat diese Anleitung absolviert.
