Zum Hauptinhalt wechseln
Axess TA2513-10WT Side Button Replacement
Was du brauchst
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: Schritt 2, Bild 1 von 3 Axess TA2513-10WT Side Button Replacement: Schritt 2, Bild 2 von 3 Axess TA2513-10WT Side Button Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: Schritt 3, Bild 1 von 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: Schritt 5, Bild 1 von 2 Axess TA2513-10WT Side Button Replacement, Buttons: Schritt 5, Bild 2 von 2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: Schritt 6, Bild 1 von 2 Axess TA2513-10WT Side Button Replacement: Schritt 6, Bild 2 von 2
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: Schritt 7, Bild 1 von 2 Axess TA2513-10WT Side Button Replacement: Schritt 7, Bild 2 von 2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: Schritt 8, Bild 1 von 3 Axess TA2513-10WT Side Button Replacement: Schritt 8, Bild 2 von 3 Axess TA2513-10WT Side Button Replacement: Schritt 8, Bild 3 von 3
    • Remove the individual buttons with tweezers.
Abschluss
Lori Scott
101 Reputation
1 Anleitung geschrieben
Baylor, Team 6-3, Shaver Spring 2015 Mitglied von Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 221
